Enable the SNMP agent process to generate authentication-failure traps.
- Select General.
- Select the Error tab.
- Select AuthenticationTraps.
- Select Apply.
Error Field Descriptions
Use the data in the following table to use the Error tab.
Name |
Description |
AuthenticationTraps |
Enables or disables the sending of traps after an error occurs. The default is disabled. |
LastErrorCode |
Specifies the last reported error code. |
LastErrorSeverity |
Specifies the last reported error severity: 0= Informative Information 1= Warning Condition 2= Error Condition 3= Manufacturing Information 4= Fatal Condition |
